rgr
How to pass SOURCEDIR property to vbscript
I have a cutum action, "Launch Attached File", that excecutes an vbscript. In the script I need de resolved directory from the SOURCEDIR property which I made under the Install parameters. How do I do that :? Please, an example would be helpful. I am trying to accomplish this but I can't figure it out from the manual.
R.Mueller
Re: How to pass SOURCEDIR property to vbscript
Hi rgr,
just use
Session.Property("SOURCEDIR")
for that (inside of your VBScript).
Roland
As Roland mentioned, if you need to get or set a property value from a VB Script custom action, then you can use Session.Property property.
Please keep in mind that only immediate custom actions have direct access to public properties. The "Deferred", "Rollback" or "Commit" custom actions will not have access to installer properties (the properties will be empty when the custom action runs). If you want to use properties in a "Deferred" custom action you need to use the Action Data field.
