pmclean2
License Agreement printing problems after upgrade to AI 10.5
The text into License Agreement box doesn't print as before after upgrade to AI 10.5.1. On version 10.3 the PushButton (Print Button) was able to print the text of the .rtf file as it should be.
Now it prints the same rtf file as some none formatted text ( big characters only)
Check the two attachments.
R.Mueller
Re: License Agreement printing problems after upgrade to AI
I can confirm the issue, I have the same problem with our EULAs. They haven't changed compared to the previous versions.
Roland
TESTEU.zip
Eula printed to PDF (zipped due to file extension limitation)
(32.17 KiB) Downloaded 766 times
Indeed, this seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing this to our attention. We'll notify you when the fix will be available.
R.Mueller
Hi Daniel,
is it possible to get a patch for that?
Roland
pmclean2
Thanks for the quick answer !
I am waiting for the fix.
Regards !
Svetoslav
A fix for this issue was already included in our next version (10.5.2) of Advanced Installer which should be released today or at the latest in the first days of the next week. I'll let you know when it will be out.
This was fixed in version 10.5.2 of Advanced Installer released on September 13, 2013.
pmclean2
Yes, it works !
Svetoslav
You're welcome.
