dvangsne
Application Pool not being selected
In my project I create a new web application. (Under the Default Web Site) Along with that, I want it to use an existing application pool. I used the Browse Application Pools wizard to allow the user to select an available app pool from a dropdown list. I use the [IISBrowsePoolsComboBox] property from the combo box in the ‘Use existing application pool’ text box. The install runs fine, but the application pool never gets set properly in the web application. Am I missing a step?
Re: Application Pool not being selected
Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
dvangsne
Actually, I’ve resolved the issue. Because IISBrowsePoolsComboBox is a private property, I had to create a public property (IISAPPLICATIONPOOL) and assign IISBrowsePoolsComboBox’s value to it on a ‘Next’ click event. In the ‘existing application pool’ value I use the public property. Everything works great now.
I'm glad you got this working. Thank you for sharing this with us. This certainly will help future users in the same situation.
