Ekki
Customization prerequisite wizard's text
I need to change some text of the prerequisite wizard dialogs.
For example:
Is it possible to do that?
Re: Customization prerequisite wizard's text
For example:
If you want to use your own welcome text instead of our default, you can override the related text information. In order to achieve that you can go in the “Dialogs” page and select the Bootstrapper UI and enable the “Override information text with .rtf file:” option. It will allow you to select a RTF file with your text.
I'm afraid you cannot achieve this.
If you have other questions, please let us know
Ekki
Dan wrote: If you want to use your own welcome text instead of our default, you can override the related text information. In order to achieve that you can go in the “Dialogs” page and select the Bootstrapper UI and enable the “Override information text with .rtf file:” option. It will allow you to select a RTF file with your text.
Thank you for reply. But what if I have multi language? Can I use few .rtf files to change welcome text in different languages?
In order to achieve that you can go in the Translations page and in the Project Strings tab you can see that there is a “BootstrapperOptions.IntroTextPath.GlobalOptions” localization ID. Also here are all your language that have been added in the multi-language project.
Edit the “BootstrapperOptions.IntroTextPath.GlobalOptions” row for each language column. For each language give the path to the related .rtf text. (e.g. for English give the path to the english.rtf … for France give the path to the france.rtf and so on).
