JaimeSG
Dynamic Registry
Hi There, i'm just new using this program, and i have to say i liked so far. But i'm having trouble trying to do some things, that unfortunately the guides and how to haven't been able to help me, meaby because i'm not understanding how to do it. So here is the thing.
I need to know if i can create a dynamic registry by selecting the features during the installation.
For example: I have around 11 features that can be selected or no, which each feature represents a letter of the alphabet.
Feature 1 = A
Feature 2 = B
Feature 3 = C
Feature 11= K
Depending on which features are selected must create a Registry containing those letters.
For example if i select Feature 1 and 3 the registry must have AC.
I was reading that you can custom the seleccion dialog, but i couldn't understand the part the check boxes and how associate with the features.
What i want to know if it's possible to do that dynamic registry.
Also if it's possible could some one provide a more detailed guide for the steps to follow?
I'm at your best disposition.
Sincerely yours, Jaime SG.
Re: Dynamic Registry
Hi Jaime and welcome to Advanced Installer forums.
In order to achieve what you want you can use the [ADDLOCAL] property which contains a list of all the features that will be installed, delimited by comma. For this you can follow the steps below:
- go in the Organization page, select each feature and modify the "Identifier" field with the name that you want to be written in the registry
- go in the Registry page and add a new registry value as in the attached image
In this case the registry entry will contain the list of features delimited by comma. If you want to have it without commas, you can copy the [ADDLOCAL] property into another property using the Set installer property predefined custom action, then write a simple custom action that removes the commas contained by the new property and write that property in the registry instead of [ADDLOCAL].
Otherwise, you can let us know so we can give you another workaround which is a little bit more complicated.
Registry Value.png (30.41 KiB) Viewed 2867 times
JaimeSG
Thank you very much for the help.
Yes i managed to get the [ADDLOCAL] property with the identifiers of each feature.
And In fact i was going to ask you about removing the commas, but you already told me how to do it, and no it's fine with this solution. I really appreciate the help and this guide, I'll check out how to make that custom action.
Again thank you so much for the help.
You're welcome Jaime. Glad to help.
