Ekki
MS SQL Server pre-selection in the prerequisites dialog
Hello.
I have predefined prerequisite SQL Server 2008 R2 Express SP2. Is it possible do not make pre-selection for "SQL Server 2008 R2 Express SP2" in the prerequisites dialog if other version of the MS SQL Server is already installed?
Re: MS SQL Server pre-selection in the prerequisites dialog
Please note that there is a Windows limitation when installing SQL Server since 2008 R2 SP1 as a feature-based prerequisite within your installation project.
So, the recommended way is to add it as a Pre-Install prerequisite. Also if the install conditions are not fulfilled, then the related dialogs will not be showed.
