Metall4You
unistall Registry Entries
Hello
I have a Registry Entrie in my setup. So when the user makes the uninstall of the Setup-Program,
the Registry-Entry should not be delete!!!
How i can mark that. i have tryd with permanent?
Thanks Ramon
Re: unistall Registry Entries
Hello Ramon,
In order to achieve that you can enable the Permanent attribute from the components properties which as been assigned to the related registry key.
However, this method has some drawbacks. By using it, the resource has to be manually repaired or deleted by the user if it gets corrupted.
Please take a look on the Prevent Repair or Uninstall article which may be useful.
Please let us know if that helped, otherwise please give us more details about your specific scenario.
Metall4You
Hello Dan
Thanks for your replay
im not sure, but the registry entry should not be deleted until the program is uninstalled.
Thanks Ramon
Hi Ramon,
I'm not sure why do you say that. The registry entry should not be deleted upon the uninstall process. Did you encounter another behavior?
Return to “Feature Requests”
