Michele
Multiple Prerequisite per Feature
Hi, I'm trying to give the users the opportunity to choose the installation of different feature.
Now, I can do this, but only for one installation at a time. I'd like to start multiple prerequisites installation (in my case 2) when an user chooses a certain feature.
I can do this in separate features, but I can't move one inside the other.
How can I achieve this? Thanks. :D
Re: Multiple Prerequisite per Feature
Hello Michele and welcome to Advanced Installer forums,
In order to achieve that you can create a new feature in the Organization page using the "New Feature" toolbar button.
Then, you can drag and drop in the newly created feature the existing ones.
Michele
Unfortunately not yet. I keep having two undraggable prerequisites as in the image. Aside the type of package (I know I can add dotNet with AdvancedInstaller), I can't drag anyone of the two package (dotNet and requiredApplication). My intention is to have two .msi packages in only one feature, so the user can install them selecting it only one time.
Situation
Situation
Senza titolo-2.jpg (373.81 KiB) Viewed 4582 times
As I said in my previos reply, you can create a new feature in the Organization page using the New Feature toolbar button. Then, you can drag and drop in the newly created feature the existing ones.
In order to achieve that you can select the Not Displayed option from the Feature Tree properties for your features, the Microsoft .NET Framework 4.5 and Required Application.
Please take a look on the following image:
Michele
Re: Multiple Prerequisite per Feature [SOLVED]
Well, with the image now I understand. Great! Thanks.
You're welcome Michele,
