Hi Rohan,
In order to reboot only after install, you can go in the
Install Parameters page and select for the
Reboot Behavior the
Prompt for Reboot when required option. Also you can enable
Perform the reboot if required without showing any prompts option if you want to reboot automatically without prompting the user.
In the
Custom Actions page you add the
Set installer property predefined custom action
with sequence. You should add it after “Install Execution Stage” >> “Finish Execution” stage. You can disable the
Uninstall option and
Maintenance option from the
Execution Stage Condition.
You can edit its event options like that:
Property: field:
REBOOT
Argument: field:
Force
I've attached a .zip archive which contains a sample that implements your scenario.
