matt123
APPDIR not changing with ProductName
I made a copy of an install project, in order to create an installer for a beta version of our software.
The software has the same executable name, but I want it to be installed as a separate application in parallel with our release version.
I generated a new product ID and changed the Product name field to <appname>BETA.
For some reason, the APPDIR, which is [ProgramFilesFolder][Manufacturer]\[ProductName] does not update to use the new ProductName. It still uses the product name from the original project. What do I need to change to make this work? Changing this by hand does not seem to work either. Is it using the executable name?
I need this to install as a totally spearate application - different install dir, new entry in add/remove programs etc.
Is there somewhere else I need to change ProductName? When I change it in Install Parameters, it seems to get picked up in some places (eg install dialog header) but not others - the APPDIR.
thanks,
matt
Re: APPDIR not changing with ProductName
Hello Matt,
In order to have a better view about this, can you please send us the .AIP (project file) and a verbose log of the installation process to support at advancedinstaller dot com so we can investigate them?
If it contains confidential information you can send us a small test project which reproduce this behavior.
matt123
Hi Dan,
Thanks for the reply. I ended up creating a new project from scratch, and got it to work.
Just for reference, I was using 10.9, and what seemed to be happening was that the changed productname was not being picked up everywhere it should have been. Closing/reopening project etc didn't help, so I just started again and now I have it working as I need it.
thanks,
matt
Hi Matt,
That is odd. I'm not sure why you encountered this behavior.
It would be useful if you could isolate the behavior in a sample and send it us alongside with a test case scenario to support at advancedinstaller dot com so we can investigate.
