r00t
Is there anyway to organize features based on directory
Hi AI,
Is there anyway to organize features based on directory structure?
for example, i have
APPDIR->[App1/App2/App3/App4]
all those forlders are under the Mainfeature for now,
but i've created 4 features now: Feature1/Feature2/Feature3/Feature4
What i want to do is to install each app based on the selection of its feature from the 'ConfigureDlg', and after the installation, i want to have those folder under my Program Files\MyApp
Thanks !
Re: And is there anyway to organize features based on direct
Since you already created the related features in the Organization page, you can select all files within a folder (e.g. App1) which you defined in the Files and Folders page and select the Move to Feature... option from the context menu, as it can be seen in the below image:
From the Feature Picker Dialog, you can select the feature to which you want to add the related resources (see the below image for your reference). A tree with all the available features will be presented. This tree has the same structure as the features tree from the Organization page.
Please let us know if you need any help.
r00t
That's exactly what i wanted !
Thank you Dan :)
r00t
i'm using a 'ConfigureDlg' to display & Choose which of these feature to be installed in a Tab "AI_CONFIG_TABHOST_PROP".
Now, what i want is , install the 'Feature 2" only if the "Feature 1" is selected to be installed, if not, it shouldn't be installed by default.
Re: Is there anyway to organize features based on directory
In order to achieve that, you can go in the Organization page and drag the Feature 2 under the Feature 1 see the below image for your reference:
Having this three structure, you cannot select to install Feature 2 without install Feature 1 but, you can install Feature 1 without installing Feature 2.
Please let us know if you have other questions.
r00t
That solved my problem,
thank you Dan. ;)
You're welcome,
