congnt92
Some little errors: shortcut desktop, file version
Hi all
I have some little errors when building my app
- I added shorcutdlg but it did not working.
- How to make the same between File version and product version.
Please help me, thanks :)
Re: Some little errors: shortcut desktop, file version
Please note that these shortcuts must be created in the Files and Folders page in order to be installed. The ShortcutsDlg doesn't create the shortcuts automatically, it simply conditions their creation. Optionally, you can use the Shortcut Wizard to assist you in the creation of all the presented shortcuts.
Please take a look on our Create shortcuts article which may be useful to you.
In order to achieve that, you can go in the Configuration tab from the Media page and edit the MSI Summary Information from the “Database” section.
In the new appeared Customize Summary Information dialog you can edit the File Version field to a specific value.
If you need any help, please let us know.
congnt92
Thanks for your help. But I don't know what I did wrong to make the same between file ver and product ver.
In File version field the default value is [|ProductVersion]. I don't change any thing here. But after I build to .exe file, I didn't get any changes from file version field :(
congnt92
Oh I'm sorry. File version always be x.x.x.x.
Product ver x >> File ver x.0.0.0
Product ver x.x >> File ver x.x.0.0
Product ver x.x.x >> File ver x.x.x.0 and this is my case (my product ver is 1.0.0 and I try to make the same between product ver and file ver but I always get the string 1.0.0.0. I thinks it is error, but it didn't :D )
Product ver x.x.x.x >> File ver x.x.x.x and in this case, they can be made the same.
If we want to make the same between product ver and file ver, we must type the product ver is x.x.x.x.
You're welcome,
If you have other questions please let us know.
congnt92
Dan wrote:You're welcome,
Hi Dan.
Thanks for your reply. I still have a problem here http://www.advancedinstaller.com/forums ... 211#p72434. Please help me :(
Please take a look on our open a special file after finish installing application forum thread which debates a similar subject.
