martinpz97
How to make install dir read only.
Hey all, all night i search in forum how to make read only the install dir like this.
To cant be changed.
When i try its again the same.
How i can to change this really i need it ?
Sorry for bad english :(.
Re: How to make install dir read only.
Please note that the Read Only Extended Attributes from the control's attributes require the use of Enhanced User Interface. Also note that the Enhanced User Interface option is handled through our bootstrapper and this require the package as an .EXE (you can have an .EXE with resources inside or an .EXE with resources next to it).
If you want to have your package as an .MSI you can set the False flag for the Enabled attribute of the PathEdit control from the FolderDlg dialog as it can be seen below. Also, you can do the same for the Browse control.
martinpz97
Really tnanks i remove and button browse and now all is fine. Realy thanks u. Have a nice work. And again be heppy to help, Good day to all moderator\admin. team :), and all Advanced Installer Users.
You're welcome,
