congnt92
Custom location log file
Hi all
I want to custom location of log file. I creat the log file by my self, from a batch file which attached in Custom action page. And if the installation is error, the "show log" option will link to my log file and open it. What should I do?
Re: Custom location log file
In order to achieve what you want you should simply check the "Enable verbose logging" option from "Install Parameters" page. When the installation fails the "FatalError" dialog will be displayed, containing the "Show log" check box which will open the installation log file.
Let us know if this helped, otherwise please give us more details about what you are trying to achieve (maybe exemplify).
congnt92
If I click finish button, log file will be opened. But I want to it open my custom log file, not MSI Log file, what should I do?
congnt92
I found the thing which I need. I must be edit the string in condition field. If I want to open a specific .txt file instead MSILogfile, what should I do?
Please take a look on our open a special file after finish installing application forum thread which debates a similar subject.
