jusher
Location of registry files
I have just installed version 11 of AI and transferred my license online to the new machine.
I am encountering a problem in that the old Windows XP system used to have the registry files in C:\Documents and Settings\All Users\Application Data\Caphyon\Advanced Installer.
The new system is a Windows 7 64-Bit box and has no such directory. The default in AI seems to be set to C:\ProgramData\Caphyon\Advanced Installer\Repository.
This location does not exist on the Windows 7 machine so I just create it, copy the dialog files in there and change the location?
Also the version I installed goes into Program Files (x86) on a 64 bit machine, is that correct?
John
Re: Location of registry files
Hello John,
Repository Manager allows you to manage dialogs, prerequisites and dictionaries in the Advanced Installer repository or change its location.
The path of this folder on Windows XP is:
C:\Documents and Settings\All Users\Application Data\Caphyon\Advanced Installer\Repository
and on Windows Vista or above it is:
Indeed, Advanced Installer is a 32 bit package type so it will be installed in the Program Files (x86) by default.
jusher
Hi Daniel,
Still getting a problem. The dialogs are present in the directory but they do not have the .aip extension?
See attached file.
John
The error message is shown in JPEG attached.
jusher
Arghhh! Looks like my fault unzipped repository files into Repository directory giving Repository/Repository/ !!!
Forget this for now I am sure it will be ok.
John
No problem John,
I'm glad you got this working. If you have other questions, please let us know.
jusher
Everything ok :oops: . Like updated interface in Version 11 :D
John
