congnt92
Edit a dialogue not on the list
Hi
I setup my app and get an error. A dialogue appear. I want to custom this dialogue but I can't found it on the list.
please see attached file and give me something if u know. Thanks
Re: Edit a dialogue not on the list
The FataError dialog can be found in the Dialogs page in the Special Dialogs section, as it can be seen in the below image:
congnt92
Oh, thanks. I saw it. I will look more closely before asking question.
You're welcome,
congnt92
Hi
I create a custom action. An attach .exe file will be run when the system has been successfully modified (commit) with enable "fail installation if custom action return an errror" option. At special dialogue >> fatal error dialogue, I see log file checkbox. But in my case, the log gile checkbox isn't display. What should I do?
In order to generate an installation log, you can check the Enable Verbose Logging option from the Install Parameters page. By enabling this option, a log file will be generated each time the install package runs. This option sets the Windows Installer MsiLogging property to v value. Windows Installer will automatically set the MsiLogFileLocation property to the full path of the log file.
congnt92
Thank you very much, Dan. God bless u :)
You're welcome,
