jaelys
Pre-installed in 32 or 64 bit os for setup.iss ?
Pre-installed, there are two identical package and set the attached file (setup.iss) separately in accordance with the 32 and 64-bit, but when pre-installed 32-bit systems, replication is always a 64-bit setup.iss I try to remove only 32 yuan, everything is normal, I have tested dozens of times, the problem always happens, how to fix it?
Re: Pre-installed in 32 or 64 bit os for setup.iss ?
Can you please make sure that you set accordingly the Supported Windows Versions in the Prerequisite Install Conditions tab of the prerequisite for each one of them. For the 64 bit version of your prerequisite you can enable just the 64-bit Windows Versions while for the 32 bit version of the prerequisite you can enable just the 32-bit Windows Versions
The mutually exclusive conditions of the files will make the package install only one of the two files on the target machine.
A prerequisite will be installed based its install conditions defined in the Prerequisite Install Conditions Tab of the related Prerequisite. The Install Conditions section allows you to condition the prerequisite based on custom searches. You can create multiple searches for the same prerequisite. In order to test a condition you can use the [Test] button.
The Prerequisite Search Dialog allows you to add a new search to the installation conditions of a prerequisite or edit an existing one.
Also, be aware by the two options below the “Install Conditions” pane:
  • Install only if at least one condition is false - If this option is selected, at least one search must fail in order to install the prerequisite.
    Install only if all conditions are false - If this option is selected, all searches must fail in order to install the prerequisite.
So, the prerequisite software will be installed according to the enabled option which refers to the install condition that you have defined before.
Also, in order to have a better view about this, you can send us your .AIP (project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
jaelys
Not wrong, I is a prerequisite for separation of 32 and 64 were set in 32-bit systems there really only 32-bit pre-installed when you install the package, but the attached file (setup.iss) to install a temporary folder , but there is always an additional 64 yuan package file (setup.iss), causing the installation to fail, if I pre-installed when only 32 yuan package that is installed, additional files are copied correctly, but as long as the two simultaneous existence, is not always set to 64 million copies of the attached file (setup.iss)
In order to have a better view about this, you can send us your .AIP (project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
Also, can you please give us more details about the behavior which you encountered (maybe exemplify)?
jaelys
I try to use a small test, there was no problem, but the same two pre-installed settings, always in 32-bit OS, in the original packaging will be copied to another set 64BIT only need to copy the setup.iss, so I no way will send you a package to reproduce the test questions
jaelys
thank, is work ^^
You're welcome,
Sreeram
I have the same problem of Installing the prerequisites on 32 Bit and 64 Bit OS. I was sending you the sample .aip through email.
Kindly let me know to which Email ID i need to send.
Regards
Our emaill address is support at advancedinstaller dot com.
In order to have a better view about this, can you please send us the .AIP (project file) so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
Sreeram
We have Licensed versions of Prerequisite which i should not share. Can you please guide me with the steps
Below was the link i was following with
http://www.advancedinstaller.com/user-g ... tions.html
Followed Steps:
For 64 Bit Windows Version Pre-Requisite with 64 bit dll's setup:
Step 1: Rightclick Pre-Install and add New Package Prerequisite
Step 2: Rightclick the Pre-Requisite and rename the Pre-Requisite
Step 3: Under properties tab, Change the Name of Pre-Requisite in Display.
Step 4: Under Install Conditions Tab, Select 64-bit Windows Version checkbox checked and uncheck 32-bit Windows Version
For 32 Bit Windows Version Pre-Requisite with 32 bit dll's setup:
Step 4: Under Install Conditions Tab, Select 32-bit Windows Version checkbox checked and uncheck 64-bit Windows Version
Above are the steps i have followed while creating the Pre-Requisites.
On installing the installer with pre-requisites, It is behaving differently.
1. At times it was successfully installing the Pre-Requisites on 32-bit windows with 32bit pre-requisite and the same installer at times showing a message that 64 bit pre-requisite setup cannot be installed
2. At times it was successfully installing the Pre-Requisites on 64-bit windows with 64bit pre-requisite and the same installer at times showing a message that 32 bit pre-requisite setup cannot be installed
Kindly let me know the way forward
Sreeram
Any help on the above....
Please note that there is no need to send us the prerequisites.
All I need is the .AIP(project file) in order to check the install conditions of the prerequisites and other settings for the prerequisites. Also, can you please attach a printscreen with the error that you get during installation? As I said, in order to have a better view about this, please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
Sreeram
Please find attached Install Conditions for 64bit and 32bit prerequisites.
Regards
Install Conditions for 64Bit prerequisite
Install Conditions for 32Bit prerequisite
Sreeram
