jkurisu
Modifying the Prequisites Wizard Dialog
I am wondering if it is possible to modify the Prerequisites Wizard Dialog.
I want to remove the Finish Button when a prerequisite is required, and I want to remove the "Click Finish at any time..." text from the Prerequisites Wizard Dialog.
I was wondering if that is possible?
Screen Shot 2014-05-22 at 9.31.20 AM.png (108.23 KiB) Viewed 1619 times
Re: Modifying the Prequisites Wizard Dialog
If you want to use your own welcome text instead of our default, you can check the Override information text with .rtf file option from the Bootstrapper UI dialog. It will allow you to select a RTF file with your text.
In order to disable the Finish control, you can go in the Properties tab of the prerequisites and uncheck the Continue with main installation even if the prerequisite is not installed option.
