jaelys
Display installation summary message language
Display installation summary (enhanced UI only) message, how multi-language translation?
Re: Display installation summary message language
By default, those strings are displayed correctly, in the installation language, if that language already contains the translations for them in the dictionaries.
However, in order to translate those strings in a language that do not have them, you can follow the steps below:
- go in the "Translations" page, "Default Strings" tab
- click on the "Localization ID" column (the rows under that column will be ordered alphabetically)
- for all the rows that start with "ActionText", double-click to the right of them, on the column with the language that you want to translate to, and add your translation there (as in the attached image)
- click on the "Save changes in a dictionary from repository" link to save the changes
- click on the "Inspect repository" link
- in the newly appeared dialog right-click on the dictionary related to your language and, if you wish, select "Send to Advanced Installer Team" so we can update the translations in our future versions
- build and run the project
Translate Strings.png (88.66 KiB) Viewed 3301 times
jaelys
Has a translation, but there are many strings did not appear here allows me to translate
