aleksandr.shtifanov
Surface frame problem
Hello AI team, i have a small problem.
I'm using Surface theme and trying to customize the border (mainly the caption).
"Use custom frame only if Aero Glass is not available" is not active.
And i was trying to follow this hint:
http://www.advancedinstaller.com/forums ... 599#p60100
What did i do:
1. i copied all frame images (from Caphyon\Advanced Installer 11.2.1\themes\common-res\frame\metroblack) to a separate folder (because i will repaint them)
(i don't think it's relevant, but still..)
2. i override (Themes -> Images) the properties to the new images.
it works fine.
3. i changed the image for the AI_CF_FrameCaption property to one from metroLime theme.
(just to check, that this changing of the image works as it should)
it works also fine (active - green, inactive - black).
4. Problem. I change (in Gimp if it's important) the image (only the color [RGB 139-168-212]), which is used for the AI_CF_FrameCaption property.
i have this in the result (see image). no frameCaption at all :( for both active/inactive windows.
no Close button visible, but i still can click on the upper right corner of the window (highlighted on an image) and there is (somewhere :) ) the X button.
Could you advise me something, to solve this?
I've also send the aip file and the image for the frameCaption i want to use to your email address.
Re: Surface frame problem
The solution presented by my colleague Daniel in this thread was to hide the related X button.
In order to suppress its functionality you need to delete the display a specific child dialog control event from the published events of the Cancel control.
Please use the following image for your reference:
So, when the user will click in that area nothing will happen. Please note that you need to delete this event from each dialog where it appears.
Please let me know if you have other questions.
aleksandr.shtifanov
Hm..my problem was not the X button. The question is, where is the frame's caption? I want just to change it's color, why it disappears?
aleksandr.shtifanov
I would appreciate, if someone could help me
mihai.petcu
Hi Aleksandr,
I replied the e-mail you sent, please see your Inbox.
mihai.petcu
For anyone else encountering similar problems, it seems GIMP or other free image editing tools are not compatible with the rendering engine.
In this thread for example GIMP vs Paint.NET both generated an image with the same bit depth but different in size (274 bytes vs 206 bytes). Also the .BMP image generated with GIMP doesn't seem to be recognized by the engine.
We recommend using Photoshop if there's a purchase choice, for any image customization.
aleksandr.shtifanov
wow, it's a miracle :)
Thank you for your help. it works.
P.s. if you change the original frame image with MS Paint, it works also fine.
P.p.s. other images (buttons, logos...), that are png, changed in Gimp, worked fine.
