pimboden40
New XML Elements On Install
Hello I have an XML that looks like this:
    <syncPaths>
    </syncPaths>
I have done some CustomDialog that lets me add as many paths to an EditBox as I want. My EditBox (Multiline) now has a value of
    C:\Path1
    C:\Path2
    C:\Path3
    C:\Path4
    C:\Path5
Now I was thinking of creating a custom action that for each path in the EditBox creates an Xml-Element under syncPaths.
So the XML should look like this:
  • <syncPaths>
    <syncPath value = 'C:\Path1' />
    <syncPath value = 'C:\Path2 />
    <syncPath value = 'C:\Path3' />
    <syncPath value = 'C:\Path4' />
    <syncPath value = 'C:\Path5' />
    </syncPaths>
Can someone help me to achieve that?
Thank you
Re: New XML Elements On Install
In order to configure the related XML file you can use our XML support. Please take a look on the XML Files Page article with related information for hints and guidance.
Also, I've attached a .zip archive that contains a sample .AIP (project file) which implements a similar scenario.
XML_Sample.zip
(3.38 KiB) Downloaded 344 times
pimboden40
Hello.
Thanks for the help.
However this isn't exactly what I need. In fact I use the described method for all the settings I have to store in the XML.
The difference in my problem is, that I don't know how many syncPath element's are going to be defined.
I have something like this
When I click on the "+"Button I show a modified Folder Page Dialog, that has an "add"-button.
This Button calls a Javascript Custom Action and concatenates the Property of the PathEdit (from the FolderPage Dialog) to the Property of the MultilineEdit
So at the end the MultilineEdit-Property has many paths separated by "\n" (newline) and looks like this:
Now each of these Paths need to create a <syncPath> element inside the XML.
So the xml then should look like this:
<syncPaths>
<syncPath value = 'C:\BitTorrentSync' />
<syncPath value = 'C:\Temp />
<syncPath value = 'C:\Documents_NoBackup' />
<syncPath value = 'C:\Tools />
</syncPaths>
There can be n syncPath elements with n>1
Thanks again for the time you took for creating the sample.
In order to achieve that you can create a text file update from the Files and Folders page. A Text File Update can be used to either create a new file with the specified content or to modify those existing using "Append" and "Search & Replace" operations.
In order to add a new line in property, please take a look on the C# custom action, new line in property forum thread which debates this subject.
pimboden40
Thanks.
I solved it using a Placeholder in my XML-Config and then replacing that with a Custom Action.
Thanks for the Help
You're welcome,
I'm glad you got this working. If you have other questions, please let us know.
