Jakob1981
UI with EULA for exe in multiple languages
Hello together,
I am facing the following problem. I use Advanced Installer Enterprise and I built a single exe file with it.
The exe file installs and deinstalls on clients without problems.
I have configured a prerequisite. In case the prerequisite is not fulfilled, a dialogue is shown to the user which informs him about the prerequisite.
So far, so good, Now I want to do the following:
I want to show every user an EULA-dialogue in his system language, no matter if he has to install prerequisites or not. I simply want to show this dialogue, nothing more. In case he has to install prerequisites, I want to show the prerequisites dialogue (as described above) and additionally the EULA dialogue.
I do _not_ want to create a msi file, I want to stick with the single exe file.
I tried various options. I enabled the EULA-box in the bootstraper-UI, so that the EULA was shown after the prerequisites dialogue. But if no prerequisites were required, the EULA dialogue was not shown too. I tried to add various languages in the Translation-Tab, but then Advanced Installer failed to built the project telling me that he does not find the EULA-file. (The file, which I added to the bootstrapper-UI and which was used correctly when not using various languages.)
I really need help. Please explain me in detail what I need to do so that I can match the following requirements:
* Use EXE (no msi)
* show EULA to every user in his system language (I want to support six main languages...)
* if prerequisites are needed to be installed, show prerequisites dialogue and then show EULA
I am very grateful for any help! Thanks in advance!
Jakob
Re: UI with EULA for exe in multiple languages
Hello Jakob and welcome to Advanced Installer forums,
In order to add an EULA to your package, please take a look on the How do I add an EULA to my package? FAQ's with related information for hints and guidance.
In order to localize the End-User License Agreement text, you can follow the steps from the How do I localize the EULA and ReadMe text? article.
Jakob1981
Hello Dan,
thanks for your answer. I followed the guidings on the pages but I am not able to solve the following problems:
* I can localize the msi dialogues, but how do I localize the bootstrapper dialogues?
* I do want to show the EULA dialogue on install - I dont want to show any other dialogues (in case all prerequisites are fulfilled), but I am not able to delete all other dialogues in the "First Time Install" Sequence - how can I do this?
Thanks for your help!!!
Jakob
Hello Jakob,
In the Bootstrapper UI dialog from the Dialogs page you can display an EULA page in the prerequisite wizard. Select the RTF license agreement file in the “EULA Path (.rtf)” field.
Please note that License Agreement dialog is shown only when at least one global prerequisite was added to your package.
After you had added other languages you can go in the Project Strings Tab from the Translations page and search the BootstrapperOptions.EulaPath.GlobalOptions Localization ID. Add the path for EULA to other languages, as it can be seen in the below image:
I'm not sure I fully understand your scenario. Can you please give us more details about specific scenario (maybe exemplify)?
Please note that dialogs with their name bold define the start of a dialog sequence. A dialog sequence refers to a set of dialogs that are displayed during the same Standard Action. Also, each sequence must have at least a dialog left in its chain (you cannot delete them).
Jakob1981
Hello Dan,
thank you - your explanations helped me, I was able to localize the EULA for Bootstrapper and for the MSI!
Still, there is the last problem: The dialogue sequence during the first time installation: There are at least four dialogues shown per default (Welcome, Prepare, etc.) - I do NOT want to show these dialogues. On first time install I only want to show the LicenseAgreementDialogue. Unfortunately it is not possible to remove those bold dialogues from the First Install Sequence. I thought about editing the ini-file for the theme, but it did not work either.
Is there any way I can adjust the "First Time Installation" Dialogue Sequence in order to ONLY display the eula? (no prepare, progress, etc.?)
That would be great! Thank you!
Greetings
Jakob
You're welcome Jakob,
Can you please take a look on the The installer only needs to show the license dialog? forum thread which debates a similar subject?
Jakob1981
Hello Dan,
that worked perfectly, thank you!
Regards
Jakob
