yeilam
Build stops on "Missing Resources". Can not fix
Build stops on "Missing Resources":
Checking builds status... done.
error.
Resources referred by the project are missing.
I pressed Locate.
Got into USer Interface -> Themes.
I replaced the "Customizable Images" with resources that do exist.
The images I specified whows on the image.
BUT:
Still build gives the same error.
I save exit - no ghelp
Automatic Fix - failed to fix
Please help
VGBS.aip
(54.21 KiB) Downloaded 324 times
Re: Build stops on "Missing Resources". Can not fix
I'm not sure why this happens. Please give us some time so we can investigate your .aip (project file) and we'll get back to you as soon as we have a conclusive answer.
It seems that your project somehow got corrupted. I'm not sure how this happened. I've attached a fixed version of your project.
VGBS.aip
(53.53 KiB) Downloaded 364 times
Let us know if this helped.
yeilam
Yes.
The AIP you sent worked for me.
Thanks.
You're always welcome.
