sjeslis
Security Warning for vcredist_x64.exe?
We updated our installers to ship our files now built with .NET 4.5.1.
Consequently, I had to add the VS 2013 C++ redistributables. On some machines I'm seeing the attached security warning dialog I think before running vcredist_x64.exe. We never had this issue with VS 2008.
Any suggestions on suppressing this?
BTW, in this example the end user selected CANCEL,
Scott Jeslis
Senior Software Engineer
Cicero, Inc.
Re: Security Warning for vcredist_x64.exe?
Security warning.png (58.97 KiB) Viewed 6045 times
Do you get the prompt on multiple window versions? e.g Windows 7, Windows Vista, Windows 8. etc.
Warning 4154.png (8.67 KiB) Viewed 6045 times
This is normal since the user canceled the prerequisite installation. Please take a look on the Why do I receive the 4154 warning? article with related information for hints and guidance.
sjeslis
Dan, we weren't concerned with the 4154 warning. We were hoping to prevent the Security Warning message without unchecking the box on it. Sounds impossible.
Scott Jeslis
Cicero, Inc.
I've tested your scenario but I cannot replicated:
  • Windows Server 2008 R2 (x64)
  • Windows Server 2012 (x64)
  • Windows 8.1 (x64)
  • Windows 7 (x64)
Can you please tell us if the related behavior can be replicated on multiple clean OSs?
If it does, can you please send us a sample .AIP(project file) to support at advancedinstaller dot com which replicates this behavior?
sjeslis
It doesn't happen all the time it seems. We have one tester that had it on multiple VMs, but never a developer VM.
We suspect if the end user unchecks "Always ask before opening this file?" then you won't see again. We're assuming us developers "unchecked" this at some point before saving our VMs.
Scott Jeslis
Cicero, Inc.
