aleksandr.shtifanov
Unable to uninstall (can only be run from a bootstrapper)
Hello Ai team.
Recently i've noticed, that i cannot uninstall the package from control panel. From the installation package it works fine. And before it worked as well.
I did some changes (obviously) in the project, but cannot understand, what causes this situation.
Could you make a hint?
I'm sending the project by email.
Re: Unable to uninstall (can only be run from a bootstrapper
I'm not sure why this happens. I've tested your installation scenario, but I cannot replicate the behavior. Can you replicate the behavior on multiple machines? If so, can you please also send us a download link to your EXE setup package to support at advancedinstaller dot com so we can test and investigate it?
aleksandr.shtifanov
Yes, unfortunately this happens on each machine.
I've just sent you the setup.
Hello Aleksandr,
After further investigation we were able to replicate the issue. It seems it can be replicated only when trying to uninstall a multilingual product installed in a different language than the project default language. This seems to be an Advanced Installer issue, thank you for bringing it to our attention. A fix will be available in a future version of Advanced Installer. We will notify you when the fix will be out.
Until then, as a workaround you should use the same Product Code for all of your installation languages. Just, go to "Product Details page -> Product IDs tab" and set the same Product Code GUID for all of your installation languages.
This was fixed in version 11.5 of Advanced Installer released on September 25th, 2014.
barrystaes
I have the same issue. We just bought Advanced Installer..
I am using v11.5.1, and created a new Proffesional project to create a MSI file for my application.
The application was previously distributed via MSI files created by InstallShield3. I have entered the same name, files and paths, ProductCode and UpgradeCode. According to my knowledge, this new MSI should work equally well with our current autoupdate feature:
msiexec.exe /fva "C:\ProgramData\OurProduct\update\OurApp.msi" /norestart
But the installation failed silently. I now have the same problem as OP:
- Our product is not listed when uninstalling programs.
- I get the same error message when running the MSI file directly.
Things i tried..
Since you mentioned locale, i looked for a way to see the used locale in InstallShield3, but i found none. I saw that the AdvancedInstaller product locale was hardcoded to "English (United States)". I wanted to add/edit and try a en_UK setting (in case it got that from the EXE) but i cant.
So that did not work.. any suggestions so i can use Advanced Installer?
Since you want to update an older installed version of your installation package, you can follow the steps from the How do I upgrade an older version of the package? article.
barrystaes
Dan wrote:Since you want to update an older installed version of your installation package, you can follow the steps from the How do I upgrade an older version of the package? article.
Thanks this worked.
I dont know what the difference was (the upgrade code was identical) but i'll send the relevant files (old MSI + bad AIP + good AIP) anyway in case its of use.
Jairo
Re: Unable to uninstall (can only be run from a bootstrapper)
Hi Guys,
I think that this problem came back after I upgrade to version 13.1 since in version 12 I don't have it.
I send my .aip project to help.
Jairo Marques
Hello Jairo,
We sent you a reply by email. If you have any questions just let us know.
MartinMorin
I am using the latest version which is 14.1.1 and I just ran into the exact same problem.
Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com, so we can investigate them?
