sujai.mca
Getting inptu from user...
thanks a lot...
I have another question. :?:
During the installation process after the welcome wizard, i have added a new dialogue which consists of user name field and emailID, the user will enter the input and when they click the next button a mail will be sent to the respective mail id, which consists the product key. In the next dialogue the user will me prompted that he has sent a product key through mail and he should enter it in the next dialogue...
I designed the dialogues, but i dono how to get the user input and handle them. do i need to write any code for these actions? :? :? :?
Can u please help me out...
Re: Getting inptu from user...
Yes, you need to write code.
Each input is associated with a public property, which you can see in the right side Properties pane.
You need to read the value of that property to get the user input.
sujai.mca
thanks,
i have c# code that can sent mail. where do i need to write that code? in the help file its stated that i need to write in a WiX file, if i write there then how can i assign it to a button click event in the dialogue box?
-Sujai
You can see my response on the "to run a windows power shell script" thread.
Return to “Feature Requests”
