richboy
Registry Entries does not exist on the deployed system
Greetings,
I have created registry entries and tried to install it severally on a windows 8 PC running on VMWare but i noticed that these values do not get deployed. Infact adding several keys did not not even change the generated file size and i was wondering if it ever added. I am using AI ver. 11.2.1
Basically what i am trying to achieve is to install JRE registry values on the system. It is a Java Web Start application so i need these values to exist in the registry so that browsers can identify them.
I created the registry on the HKEY_LOCAL_MACHINE\Software directory but it wasn't working, i changed it to the Current User/Local Machine, it still wasn't working, i created on both and it still wasn't working...in all these the file size was just the same. I have cleared the cache and rebuilt, same!. I even made a copy and downgraded the aip file to ver. 9.6.1 and it still didn't work ("I only tried for the HKEY_LOCAL_MACHINE\Software" folder).
I have checked "Create (if absent) at install" option from the Edit Registry Dialog but i had no joy. I just cannot find the keys on the deployed system. I do not know why the file size wont just at least increase based on additions.
I have not tried it on any other OS.
Current Registry Settings
screen 1.PNG (58.38 KiB) Viewed 1657 times
Re: Registry Entries does not exist on the deployed system
Please keep in mind that if the components of those registry values are not marked as "64-bit Component", then the related registry values will be redirected under "Wow6432Node" registry key on 64-bit machines. So, can you please check if the related registries are installed under "Wow6432Node" registry key (if you are testing the setup on a 64-bit machine)?
In order to install a registry value in the 64-bit of the registry (this stands only when installing on 64-bit machines) you can go to "Registry" page, select the registry and from its context menu choose "Go To Component" option. Then, just enable the "64-bit Component" flag for the selected component.
