Hi Nir,
Maybe you mean a "Start service"custom action which, indeed, is not available in Advanced Installer.
However, you can add a "Launch file" custom action and use the "SC" utility to start your service as suggested in the
Start a 64 bit service thread.
Maybe we will consider your suggestion for adding this custom action, but for the moment there are not immediate plans. Thank you for your suggestion.
