mbilet
"Reset" button doesn't work properly
I found the issue with "Reset" button on "Select the way you want features to be installed" window. It doesn't work properly.
After first time it is clicked happens nothing. It really resets the original folder path only after second click.
Reset button.png (20.5 KiB) Viewed 4673 times
Environment:
- Win 7;
- AI 11.1
Mykola
Re: "Reset" button doesn't work properly
Hello Mykola,
This seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
On the first Reset button click the features are updated to their default installation behavior defined in the Organization page, and only after the second click, the installation path is reset to the default value.
mbilet
Thank you Dan
Please inform me once it will be fixed.
- Mykola
You're welcome Mykola,
We will notify you when the fix will be out. If you have other questions, please let us know.
This was fixed in version 11.6 of Advanced Installer released on October 23rd, 2014.
