LilianaV2o
install verification command line (newbie Question)
I am new to installers, My Installation requires 2 other installation package to be installed (eg bundle.exe and installer.exe). one of the package (Bundle.exe) required me to use command line for pre/post install verification,
for pre install verification command line *Bundle.exe /u http://www.xxxxxxx.com/index.php /t /ci XXXXX /i XXXXXXXX this is to check if the component is already installed
how will i do this?
I am using AI v11.2.1
Thanks in advance,
Lili
Re: install verification command line (newbie Question)
Hi Lili and welcome to Advanced Installer forums,
Since your application require two other applications to be present on the target machine, the right approach is to add the related applications as prerequisites. In the Prerequisite Install Conditions Tab you can set the install conditions of a prerequisite.
Please take a look on the Add Prerequisites article with related information for hints and guidance.
LilianaV2o
Hello Dan,
Sorry for my late reply,
I already put my two other application as prerequisites.
I got a "failed Installation" please help me out,
in the Bundle.exe tab install conditions, i create new search under the criteria of "search done by a custom executable",i set the exe path them i put the command line in the "Arguments"
the other one (installation.exe) is failed to launch.
what did i do wrong? or is this all wrong? :D
Regards
Lili
