dexter_v
uninst.exe
Hi
I'm new to advanced installer, just trying out the trial version.
How do I create a uninst.exe (i.e an uninstaller) and package it along with the installer. So that the user does not have to go to the control panel and uninstall the application. By clicking on the uninst.exe the user should get the wizard for uninstallation.
Can I do this in advanced installer?
Re: uninst.exe
With Advanced Installer is very easy to create a shortcut that will uninstall your application.
In order to achieve that, you can use the Shortcut to -> Uninstall toolbar option from the Files and Folders view to create a shortcut that will uninstall the application.
Use the attached image for your reference:
In this case the shortcut will be created to the Desktop folder. You can also take a look on the Create shortcuts article which may be useful to you.
dexter_v
Re: uninst.exe
Thanks Dan, It really helped
Re: uninst.exe
You're welcome,
