Hi Gopal,
1. Show all the EXE's list so that the user can choose them. Since we have four EXE we will show the user the list as A,B,C,D. Suppose he chooses A,B and D then we will install only A,B and D. Is it possible to it?
Yes, this can be done through the
Convert EXE(s) to MSI approach.
At the 4th step (
Configure .EXE packages), when you are asked to select the .EXE package, please add all your four .EXE files.
Please note that once an .exe has been added, a new
feature has been created in the
Organization page.
Then, you can go in the
Dialogs view and add from our predefined
list of dialogs the
OptionalFeatsDlg to control with the function to check or uncheck all features in the list. This way, the features will be installed accordingly.
2. Clean uninstall if installation fails.if any one of the installation fails then we need to roll back the installed exe's
Because the .EXE packages are added as Post-Install prerequisites, you cannot roll back the installed .EXEs. You can try to add them as
Feature-based prerequisites and see if this works.
Also note that when installer is run in quiet mode, Feature based prerequisites are installed after main installation. When in GUI mode, Feature based prerequisites are installed before main installation.
