Calvin
Access Database Engine 2010 prerequisite issues
Hi, I'm using Advanced Installer 11.4.1 (latest version before our maintenance plan expired) and I'm having problems using Access Database Engine 2010 as a prerequisite.
The resulting installer always prompts users to install Access Database Engine 2010, even if its already installed. If the users accept Advanced Installer's prompt, the ACE 2010 installer itself does ask the user to repair/uninstall/reinstall as appropriate. Same thing with Access Database Engine 2007.
I am using the ACE redistributable downloaded here: http://www.microsoft.com/en-us/download ... x?id=13255
Has this issue been resolved in recent versions, or is there some other way around this?
Thank in advance.
EDIT: Attached screens:
Screen of Advanced Installer.png (16.69 KiB) Viewed 5570 times
and
Screen of ACE 2010 installer.png (17.46 KiB) Viewed 5570 times
Re: Access Database Engine 2010 prerequisite issues
Hi Calvin and welcome to Advanced Installer forums,
This may happens if the install conditions have been modified.
Please note that a prerequisite will be installed based on its install conditions defined in the Prerequisite Install Conditions Tab of the prerequisite.
Can you please check if the install conditions have been modified?
Calvin
Ah, silly me! The install conditions were changed to "Always install prerequisite"!
Thanks so much for the help!
You're welcome Calvin ,
