jusher
ICE38 Error
I get this error when running MS Platform tests: -
ICE38 ERROR Component CommsWare installs to user profile. It must use a registry key under HKCU as its KeyPath, not a file.
What do I have to do to get rid of this error. I have tried the validation test through ORCA and it is the same.
All my aip files use this see attached image.
Quick Launch gets the same ICE error: -
ICE38 ERROR Component QuickLaunch installs to user profile. It must use a registry key under HKCU as its KeyPath, not a file.
John
Re: ICE38 Error
Hi John,
Can you please try to use the fix it! button and see if the behaviour still persist? Please see the attached image for your reference:
Let us know if the behaviour still persist.
jusher
Re: ICE38 Error
Sorry Dan,
There are no issues in AI application.
I do not get any errors when building.
It is when I run validation through ORCA and especially through Microsoft Platform testing.
John
Re: ICE38 Error
Hi John,
Please note that you can enable the validation tool inside Advanced Installer too. All you have to do is to enable the Enable ICE validation for Msi packages from the Package Validations dialog.
The validation result is displayed as information in the build log and will not affect the build result. After the build operation is finished the validation result is displayed in the Issue Pane list allowing user to locate the problem in Advanced Installer UI (if possible). In your case, please select the ICE38 error and use the Fix IT option.
jusher
Re: ICE38 Error
Hi Dan,
I can't see this dialog in the AI tool.
Do I need to install something else?
John
jusher
Re: ICE38 Error
I already ran MsiVal2.msi
John
Re: ICE38 Error
Hi John,
In order to enable the Enable ICE validation for Msi packages option, you use select the File -> Options -> Package Validation option. Please use the attached image for your reference:
After building the project and hit the OK button, you can fix the ICE38 warning as advised in my previous reply.
Please let me know if you need any help.
jusher
Re: ICE38 Error
Hi Dan,
Thanks the ICE38 Errors cleared with Fix It!
Now there are a few more that have failed but some seem to be that there are no events on Back buttons etc. "Do nothing buttons" mostly with unused dialogs. Any idea what I should do about these?
One though fails ICE99: -
The directory name: WindowsVolume is the same as one of the MSI public properties and can cause unforeseen side effects.
It also says there is no automatic fix. This is created when you start a new project.
John
jusher
Re: ICE38 Error
As well as the above I have: -
'The keypath is currently Null'. at the end of the first error (original post) about HKCU, which I had assume was fixed with 'Fix it!'
John
Re: ICE38 Error
Hi John,
As I can see, the ICE99 verifies that no property name entered in the Directory table duplicates a name reserved for the public or private use of the Windows Installer.
However, I'm not sure how this can happens, to use a reserved name as WindowsVolume. In order to have a better view about this, can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
jusher
Re: ICE38 Error
Windows Volume is shown in the file tree if you open up a new project.
It is always created for you.
The [WindowsVolume] property is also available.
It is not something I have created.
I will send you the project.
John
