scotcro
SQL Database Browse
I cannot figure out why I cannot get a ComboBox to populate with the databases from a database on the local machine when I click a button.
If I configure the Sql Browse function to trigger on the SQL Dialog Initialize then I get 1 of the real database names in the combo list.
if I change the combolist to just a list and change the Sql Browse function to fill it, then I get the list but *ONLY* when set to browse on SQL Dialog Initialize.
Note: the Trusted Connection checkbox is not wired up to anything yet.
Re: SQL Database Browse
This may happens because Windows Installer does not refresh the dialog when you execute the event from the related button. So, this is a Windows Installer limitation.
To overcome this, you can use the following approaches: To visually discover this feature from Advanced Installer, you can take a look on the SQL Browsing video.
