Hello Gerhard and welcome to Advanced Installer forums,
I have various builds which must each write a different value to a registry key. So I created a property with values defined for each build. When I define the registry key as a DWORD then it fails to create.
If the property value does not represent a number, the registry entry will fail to create them as DWORD.
If I make it a string the key is created but the value is empty.
This may happens if the property is empty. In order to have a better view about this, can you please send us the .AIP (project file) and a
verbose log of the installation process to
support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behaviour.
In order to add registry keys and values to your package, please follow the steps from the
Add registry article.
