dashchi
How to show or hide a text in progress dialog
How to show or hide a text control in progress dialog according to installing .net 4 or not?
I added an event to the text control and tried many conditions. But it didn't work as I need.
I just want to show a text control which tells user be patient if installing .net 4.
Does any one know? Thanks a lot!
Re: How to show or hide a text in progress dialog
Please note that the recommended approach to install the .Net Framework prerequisite is as a Pre-Install and you can see here Why does .NET Framework fails as feature-based prerequisite?.
When the Net Framework prerequisite is added as a Pre-Install prerequisite, the bootstrapper can display the following dialog (only if the .Net Framework is added from its online location):
Bootstrapper 3rd dialog.png (40.27 KiB) Viewed 3120 times
and the following dialog during installation:
Bootstrapper 4th dialog.png (65.02 KiB) Viewed 3120 times
You may suppress the Net Framework prerequisite UI through the Install Command Lines field from the Prerequisite Setup Tab using the following command line:
/q /norestart
Please note that the Bootstrapper UI can only be customized from the Bootstrapper UI from the Dialogs page.
dashchi
Thank you very much!
But how can I edit the prerequisites install dialog?
Why can't I find it in the Dialog UI Section?
You're welcome,
I'm afraid that the related dialog is displayed by the bootstrapper and it cannot be customized. This is why it is not displayed in the Dialogs sequence.
dashchi
Thanks a lot! Now it looks much better than before.
You're welcome,
