HI,
I am trying to find a solution to a problem. I have my installer completed and working perfectly but I need to have a new option.
I would need the installer to detect the presence of a install.ini file in the same directory when started... if the file is found, it would then read the values into it and use them as parameters to run the installer as silent .... the values that are usually chose by the user in ComboBox would be replaced by the values in the ini file and the same behaviours would then happen... the search and replace and service install and all the rest of the installer would work the same except it would run silently.
To be more specific, I want the installer to run silently and automatically using values in the ini file as parameters for the rest of the installation ONLY if there is a install.ini file in the same directory.. otherwise, it would be a normal install with user inputs.
Is it possible ?
PAt
