Meena
SCCM Feature
Hi Support,
Could you please tell me the use of SCCM feature in Advanced Installer.
Meena
Re: SCCM Feature
Hi Meena,
The Advanced Installer SCCM support further simplifies the task of deployment application using System Center Configuration Manager.
If you are using SCCM 2007 or 2012 you can save time by deploying your applications (MSI, MST and EXE) directly from Advanced Installer's GUI or by creating a simple script that calls our tool from the command line.
Our SCCM deployment wizard allows adding packages into SCCM directly from your packaging/development machine, as long as you have the credentials to connect to your SCCM server.
Software packages are automatically configured for the most common deployment scenarios.
Support for the latest deployment models: If you have other questions, please let us know.
Meena
Re: SCCM Feature
Hi Dan,
Thanks for your reply. Do I need to install SCCM 2007 or 2012 in order to utilize the SCCM feature in Advanced Installer?
Meena
Frank Bastiaens
Re: SCCM Feature
Hey meena,
No you don't have to install SCCM on your package machine, you need a running SCCM server on your network, as the feature connects to that sccm server.
Regards, Frank
Re: SCCM Feature
@Meena: As Frank said, you need a running SSCM server on your network. You don't have to install SSCM on your machine. Advanced Installer SCCM will try to connect to that SSCM server.
@Frank: Thank you for your fast reply.
