walteste
Signtool - Error while building
While building my project with my new digital signature settings the following error comes up:
The digital signing of the C:\Program Files (x86)\Caphyon\Advanced Installer 12.0\custact\x86\aipackagechainer.exe file failed. Error Message:SignTool Error: Invalid option: /fd
The digital signature settings and the error dialog are attached as images.
My build system is: Windows 7 x64 with Advanced Installer 12.0
What I am doing wrong and how can I fix this?
Stefan
EDIT: it seems that the /fd option is caused through the setting "Use SHA256 as digest algorithm".
Advanced Installer - Build Error.png (98.31 KiB) Viewed 3117 times
Advanced Installer - Signature Settings.png (19.92 KiB) Viewed 3117 times
walteste
Re: Signtool - Error while building
I solved it by myself through the following forum post: http://www.advancedinstaller.com/forums ... 256#p68182
I changed through the settings "External Tools" - "Signtool" to a newer version.
