kjullion
.NET 4 Fx pre-req installation is failling
Lately I have seen this error message:
quite often, even though I have made no recent changes to my installer (AIP files).
My test scenario is to install our package onto a Win7 x64 Oracle VM. I can see that he .NET Fx 4.0 download seems to occur without issue.
What can I do to get this resolved?
Kevin
Re: .NET 4 Fx pre-req installation is failling
Hi Kevin,
This may happens if the install condition of the prerequisite is not meet after the prerequisite is installed. A prerequisite will be installed based its install conditions defined in the Prerequisite Install Conditions Tab of the related Prerequisite. The Install Conditions section allows you to condition the prerequisite based on custom searches. You can create multiple searches for the same prerequisite. In order to test a condition you can use the [Test] button.
So, can you please make sure that the .Net Framework has a correct install condition defined (you can add it once again from our predefined list)?
