chandrabhushan
Build MSI Package of more the 3 GB size
Hi
I want to Build a MSI Package with "either resource next to it or resource inside " but getting error as size of CAB file can't be more then 2 GB .
Please help me with this .
Please note that i will prefer the MSI build with resource inside .
mihai.petcu
Re: Build MSI Package of more the 3 GB size
Indeed the CAB size cannot exceed 2GB. The solution is to organize your installer into Features from the Organization page. On the Builds page -> <your_build> -> Configuration tab select the "One CAB archive per feature" option. Also, make sure your features have each less than 2GB.
Unfortunately this option requires the "MSI with resources next to it" build type.
