ANikolova
VSTO doesn't get detected
I have a client setup with a Search action that is configured the following way:(attachment 2)
However, when setup is started it doesn't detected that VSTO is installed(as shown in attachment 2), and the setup fails, because it tries to install it again.
What am I doing wrong, how can I surely detect that VSTO is installed?
This is the link to the verbose log from the setup run: https://drive.google.com/file/d/0B6YEop ... sp=sharing
With regards,
Anna Nikolova
setup project.jpg (37.21 KiB) Viewed 3778 times
Re: VSTO doesn't get detected
Hi Anna,
I assume that you have added the Visual Studio Tools for Office 4.0 Runtime as a prerequisite to you installation package, right?
Did you added VSTO from our predefined list of prerequisites? If Yes, the install conditions for the related prerequisite should be already defined in the Prerequisite Install Conditions Tab. Please note that a prerequisite will be installed based on its install conditions.
As I can see, the search criteria is of Registry value containing a version in order to check if the Visual Studio Tools for Office 4.0 Runtime is installed, while the registry path is:
HKLM\SOFTWARE\Microsoft\VSTO Runtime Setup\v4R\Version
and the Minimum required version is:
Please let me know if that helped. If you can't get this working, can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
