I ran into problem after installing multiple products/projects.
Uninstallation runs smooth when I have one product installed. When I have mutiple product, it does remove the files and registry entries but fails to remove the entry from the program list (in control panel).
Say if I have products p1 and p2 installed at the same time, uninstalling p1 leaves its entry in programs list. I can remove it if I uninstall p2 and install p1 and uninstall p1 again, which is quite annoying.
I have made sure I have diferent product code and Upgrade code for both p1 and p2.
Tried enabling verbose logging but had no luck in tracking the issue.
I didn't change company name and product version, they are as it is.
Please let me know where I might be going wrong. Looking forward to hear back.
