narsingani
Check TCP port using existing property
I have been working on this but do not see any way to use existing property as I am already requesting a user to enter SQL Server IP, Database name, Username, password and Port details during the installation process. It would be much easier if we can use the existing property for Check TCP port function as well. This could be the same for Host name or IP field as well.
Thanks!
Upendra
Re: Check TCP port using existing property
Hi Upendra,
I'm afraid that I do not fully understand your scenario. Can you please give me more details (maybe exemplify)? Which properties do you want to use and where?
narsingani
Hi Eusebiu,
During the installation process, I am requesting user to enter PORT(PORT_PROP) details which is going to be used by the borland socket server once the service is installed. So when I already have the port and Server details in my installation step, why can't I use the same Port details to check whether this port is available or not? Currently, when I try to use existing property from SQLConnectionDlg for TCP port check, it does not allow me to select any (Only accepts manually entered value). Please see attached screenshots.
Hope this makes sense. Thanks!
Upendra
Hi Upendra,
Indeed, you cannot use a property in the "Check TCP Port" custom action. If you want to check for a port that the user types you need to use the predefined "AI_SEARCH_TCP_PORT" property instead of "PORT_PROP" or you can create a "Set installer property" custom action that sets the "AI_SEARCH_TCP_PORT" property to the value of the "PORT_PROP" property.
For more details you can take a look on the "How to get a free TCP port by using a custom action" tutorial.
Return to “Feature Requests”
