ajvpr
Licensing Library Properties not available on Trial
I want to be able to figure out in my application how many days are left in my trial license so I can display some alerts. I can get all the available properties on a regular valid license but I don't seem to get any relevant values when I'm in a Trial License.
I'm looking at the "TrialLeft" property in specific.
Is this a limitation of the Licenser module or am I doing something wrong?
Re: Licensing Library Properties not available on Trial
I've tested your scenario and it worked as expected.
I've successfully read the value of the TrialLeft property.
Can you please tell us how you read this property? Can you give us a test case scenario?
By the way, what application do you have? Is it developed in C#? For C# application, you should have something like that:
// Get TrialLeft property
        StringBuilder trialLeft = new StringBuilder();
        UInt32 len = (UInt32) trialLeft.Capacity;
        if ( GetPropertyValue("TrialLeft", trialLeft, ref len) == 234 )
          trialLeft.EnsureCapacity((Int32)len);
          GetPropertyValue("TrialLeft", trialLeft, ref len);
		  TrialLeftBox.Text = trialLeft.ToString();
        Debug.WriteLine("TrialLeft=" + trialLeft);
When the app is started, the trial period is properly displayed:
ajvpr
It's a java application. Here are the steps I'm taking to get to the point where I display some of the properties:
1. Load the licenser DLL
trialLib = (TrialLibrary) Native.loadLibrary("TrialLib", TrialLibrary.class);
2. Call ReadKey
 trialLib.ReadSettingsRetStr(libraryKey, null);
3. Go on to the main application and display properties
AdvancedLicenseLibrary.instance.GetPropertyValue("TrialLeft");
We apologize for our delayed reply, but we were a bit busy lately.
When using our Licensing feature (trial.dll) for a java application (defined as a java product in our "Java Products" page) you don't need to dynamically load our trial.dll within your java application code.
We have enhanced trial support for Java Products and all you have to do to call the "GetPropertyValue" function of our trial.dll is to:
1. declare the "GetPropertyValue(String aName)" native method in your main class exactly like this:
public native static String GetPropertyValue(String aName) throws Exception;
2. and then call the "GetPropertyValue(String aName)" method from your java application code like this:
try {
    String value = GetPropertyValue("TrialName");
} catch (Exception e) {
    e.printStackTrace();
For your future reference you can take a look on our "Integrate Licensing support in Java applications" and "Retrieve Licensing Elements" user guide articles.
If there is anything we can assist you with just let us know.
