ameen.jinnah
Product Name not changing for Multiple Instance's Upgrade Version
My installer is used to install Multiple instances of application in a server. It has no problem when I install new instance with the same build or version number. Whatever new instance name I'm providing, it exactly replaces in the path as well as Product Name. But when I re-build the installer with next version number for upgrade and try to install new instance directly, it does not take the New Instance Name. Instead it uses the default Product Name. Even if I change the path manually, the product name still takes the default name, which is causing lots of confusion. I have attached the AIP file.
I need to achieve "Product Name and Path must be resolved properly for any new Instances". Kindly advise what I'm missing.
Thanks.
TestInstaller.zip
(5.64 KiB) Downloaded 418 times
ameen.jinnah
Re: Product Name not changing for Multiple Instance's Upgrade Version
Can someone help me on this.
Thanks.
Indeed, the dialog that shows the instances is buggy, so we will fix it in a future version of Advanced Installer. Thank you for bringing this to our attention.
Normally, the default instance (which name cannot be changed) should always be upgraded to the latest version. Actually, the instance which name is not updated as you expect, is the default instance and the different versions that have the same name (in your screenshot) are pointing to the same instance (default instance).
Meanwhile, the normal approach, when you upgrade to a new version, is to first upgrade the default instance by using the "Maintain or upgrade an already installed instance" option and only after this add a new instance which will accept a new name.
ameen.jinnah
Hi Eusebiu,
Thanks for your update. I thought I really messed up with my installer.
Kindly let me know once this issue is fixed.
Thanks.
You're welcome.
We will update this thread when the issue will be fixed.
This was fixed in version 13.5 of Advanced Installer released on December 14th, 2016.
ameen.jinnah
Hi Dan,
I have upgraded to version 13.5 and tested this scenario. I found the New Instance Name is replacing properly but the new instance name is not replaced in the file path. Please advise.
Thanks.
Can you please give us more details about the encountered behaviour, maybe attach some printscreens so we can have a better view about this?
