Eric_Liu
Advanced Installer 13.5 not comptible with Flash player 24.0.0.186 NPAPI ?
First, I've downloaded the install_flash_player_24_0_0_186_plugin.msi from https://www.adobe.com/products/flashpla ... ution.html
Then , I created the new transform (mst) for install_flash_player_24_0_0_186_plugin.msi
Add mms.cfg to flash folder
Save the mst file and confirmed the build has finished successfully
However, the MSI file is unable to install when using the transform file.
Please fix this bug in next version, thanks.
Re: Advanced Installer 13.5 not comptible with Flash player 24.0.0.186 NPAPI ?
Unfortunately, for the moment we don't have an MSI of the Adobe Flash Player. Could you send us a download link for the MSI you are using to support at advancedinstaller dot com so we can test the scenario?
Also, can you please implement the workaround from our "Adobe Flash Player 13 ActiveX Installer" thread and let us know if this works?
Eric_Liu
The source can be downloaded from
https://drive.google.com/open?id=0Bw8H3 ... 0ZsYmJHUTA
There is no problem with Advanced Installer 13.1
So, this should be a bug on ver.13.5
Thank you for the sent MSI file. I've tested the scenario using Advanced Installer 13.5, but the installation was successful when using the built MST file. I've run the tests on a Windows 8.1 machine
Can you please give us a detailed description of the steps you do when you replicate this issue?
Eric_Liu
Hi Daniel,
Here is the step.
First, launch the Advanced Installer 13.5
Click New -> MST -> New Transform, then select install_flash_player_24_0_0_186_plugin.msi
Click Files and Folders -> expand Windows Volume\Windows \System\Macromed\Flash , click Flash Folder , then Add mms.cfg file
Click Builds, then click Save As Transform to export the mst file.
Copy install_flash_player_24_0_0_186_plugin.msi, Adobe Flash Player 24 NPAPI.mst and Cab1.cab to other Windows 8.1 machine.
Start the msiexec with transform file, an error occur.
Thank you for your feedback. I've tested again this scenario and I was able to replicate the behavior. This seems to be an Advanced Installer issue, a fix will be available in a future version of Advanced Installer. Thank you for bringing this to our attention.
We will notify you when the fix will be out. Until then, as a workaround you can proceed like this:
1. after adding the cfg file in "Files and Folders" page go to "Table Editor" page
2. select the "File" table and here edit the "Attibutes" column of the "mms.cfg" file row like this:
3. save the project as an MST file and test again the built MST
Let us know if this helped.
A fix for this issue will be added starting with our next version of Advanced Installer (13.6).
We will update this thread as soon as the next version will be out.
This was fixed in version 13.6 of Advanced Installer released on February 15th, 2017.
Eric_Liu
Hi support Team,
Confirmed that this bug is fixed in v13.6.
However, when I tried to remove the Flash player, the mms.cfg (which I have added via transform) still persist at C:\Windows\SysWOW64\Macromed\Flash
Is it a bug ?
