SingleP
Identify instance install condition
I'm using multiple instances, generate instances at installation time.
When i installed more than 1 instance i had a dialog that offered me 2 options.
A- Install new instance
B- Maintain or upgrade an already installed instance
How can i identify if i choose for option A or option B on multiple instance dialog ? i.e, i'm trying to achieve parameter or condition that could help me to build customize dialog depends on selected option(A or B).
SingleP.
Horatiu
Re: Identify instance install condition
To see what option was selected you need to use the property INST_RADIOBUTTONGROUP_PROP
It has the value:
1. For a new installation NewInst
2. For Maintain or upgrade MainInst
If you have similar issues, you can check the values of properties during installation and much more in the Advanced Installer log.
~Horatiu
SingleP
Thanks for answer.
Do you know if i suppose to see that property using smart condition ?
Horatiu
Hello again,
Yes, you should see the property using Smart Condition Edit Control.
~Horatiu
SingleP
Sorry, i can't find this property.
Did you configure some options on your project to display that property? or does it support enterprise ? or does it pushed to latest versions ?
Thanks in advance.
Horatiu
The option to create Multiple Instances is supported from Enterprise edition upward. You can check if the property exists in you project,
by going to the Table Editor and selecting the Property table.
I have attached a small sample project to help you. Just added an instance in the Multiple Instances section,
and displayed a dialog depending on the value of the property INST_RADIOBUTTONGROUP_PROP.
~Horatiu
Sample.rar
(3.12 KiB) Downloaded 375 times
SingleP
Thank you.
I'm using Enterprise 12.7 .
I think it doesn't support this version and i should upgrade to a newer version.
I can't open the file since the file is formatted from 13.5.
Last question, before i will upgrade to a newer version.
Does it works with multiple instances, 'Generate instances at installation time' option ?
Thanks for help.
Horatiu
No problem.
Yes, the Generate instances at installation time option is present in version 13.5. Before upgrading, I recommend you install the trial version,
and check that everything is OK with your projects.
~Horatiu
SingleP
Generate instances at installation time option is present on previous versions as well but probably the INST_RADIOBUTTONGROUP_PROP prop doesn't , and that's what i'm looking for.
I will install the trial first and verify that everything is fine as u suggested.
Thank you very much for your time.
