kietvta
Error "Could not access network location WindowsVolume"
Hi all
I add a Dialog for user to select a second installation folder during the installation, in addition to the Application Folder. I did that as the following instruction: http://www.advancedinstaller.com/user-g ... older.html but it raised
an error "Could not access network location WindowsVolume". How can I solve it?
Please see my .api attachment file for details.
Thanks in advance.
Kietvta
PACS WORKSTATION - Copy.rar
(66.76 KiB) Downloaded 400 times
mihai.petcu
Re: Error "Could not access network location WindowsVolume"
Dear Kietvta,
The error is shown from the "SetProperty" custom action. As indicated in the article, you have to set MY_DIR property to [WindowsVolume] instead of WindowsVolume.
This is because the "Value" field is formatted and the correct way to reference installer properties is between straight brackets.
kietvta
The problem was solve. Thank you so much.
May I have more question. How can I set default path value for the Folder Dialog.
Please my illustration image I attached here.
Thank you.
You can set the default path of the installation folder from "Install Parameters" page -> "Application Folder" field.
